Activity Forums Adobe After Effects VOB File Conversion for Mac
  • VOB File Conversion for Mac
    Posted by Max Morse on January 30, 2010 at 10:51 pm
    Hi everybody …
    I recently was sent a few .VOB files that a client wants me to re-cut into a project in FCP. I tried using Handbrake, but i keep getting “No Valid Source Found.” Anyone know what I’m doing wrong or if there’s another free program that can help?
    Thanks in advance!!!
    ~ max
    Chris King replied 12 years, 4 months ago 6 Members · 5 Replies
  • Simon Bonner
    January 30, 2010 at 11:36 pm
    Hi Max,
    There’s probably a ‘proper’ way to do this, but I would just change the file extensions from VOB to MPG.
    Simon Bonner
    youtube.com/simonsaysfx
  • David Johnson
    January 31, 2010 at 1:58 am
    As Simon says (no pun intended), you can just change the extensions to MPG … if I recall correctly, FCP won’t read the muxed audio so you might first have to open the MPGs with QuickTime and export the audio as AIFs, then import those into FCP to put back with the MPG video.
  • Michael Szalapski
    January 31, 2010 at 2:32 am
    Also, just as an aside, AE is a terrible program for dealing with this issue. The reason? VOB’s are encoded with MPEG-2. Why is that a problem? I refer you to Dave LaRonde:
    Dave’s Stock Answer #1:
    If the footage you imported into AE is any kind of the following —
    footage in an HDV acquisition codec, MPEG1, MPEG2, mp4, m2t, H.261 or
    H.264 — you need to convert it to a different codec.
    These kinds of footage use temporal, or interframe compression. They
    have keyframes at regular intervals, containing complete frame
    information. However, the frames in between do NOT have complete
    information. Interframe codecs toss out duplicated information.
    In order to maintain peak rendering efficiency, AE needs complete
    information for each and every frame. But because these kinds of footage
    contain only partial information, AE freaks out, resulting in a wide
    variety of problems.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Walter Soyka
    January 31, 2010 at 12:31 pm
    AE is not the tool for this.
    Try MPEG Streamclip; it’s a great tool, and it’s free. You can use it to transcode VOB to whatever format (DV, ProRes, etc.) that you’re editing with in FCP.
    It relies on the Apple Quicktime MPEG-2 playback component; I believe this is now part of the standard Final Cut Studio install, but it’s also available separately here.
    Walter Soyka
  • Chris King
    April 10, 2014 at 5:56 am
    VOB is the format used in DVD and will not open in Apple’s video player, video editing software easily. I want to edit and play some VOB files on Mac, but the video player QuickTime, and editing programs like FCP can’t support the VOB format.
    What I can do is to convert VOB to MOV, a Mac fully compatible format. To convert DVD VOB videos for playing, editing on Mac, it’s undoubtedly that a video conversion program is needed. You can just get freeware like Handbrake to make it. If you are not satisfied with the output quality, you can try some 3rd party VOB converter for Mac without any losing quality.
