Activity Forums Apple Final Cut Pro Legacy VO Tool Record button grayed out.
  • VO Tool Record button grayed out.
    Posted by Eli Mavros on February 13, 2006 at 6:48 pm
    Why am I able to get levels on the VO tool but I cannot hit the record button to capture. I have my source set to AJA Kona. The button appears to be grayed out.
    Eli Mavros
    Eli Mavros
    Joni Church replied 20 years, 7 months ago 2 Members · 1 Reply
  • Joni Church
    February 13, 2006 at 7:16 pm
    Have you set an IN and and OUT on your timeline? You need to set and IN and an OUT or you won’t be able to record.
    Also if you don’t already know, you can only record 5 minutes (I believe) after the end of your video, so if you’re recording into a sequence with video and you want to keep going after it has finished, throw in a slug at the end.
    Hope this helps,
    Joni
