Activity › Forums › Apple Final Cut Pro Legacy › VO media from FCP voice over tool gone missing..
  • VO media from FCP voice over tool gone missing..
    Posted by Mark Shepherd on March 20, 2010 at 5:58 pm
    For some reason, all my temp VO tracks that were generated from the VO tool have now gone missing. The numbered VO tracks (about 30 or so) now have turned WHITE in the sequence. I have tried to locate them using the reconnect media window by they can’t be found. Does someone out there know where this media resides on the drive. What folder? and the b est way to connect them all if I find them? Thanks in advance, wise master of FCP Studio 6.05 realm..
    Jerry Hofmann replied 16 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 21, 2010 at 3:17 am
    When you use the VO tool, it goes in the same folder your scratch is set to go to… look where it’s set to be, and that’s where you’ll find them. If you want them to be in your browser too, you need to import them, or just drag them from the timeline window up to the browser.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
