Activity › Forums › Apple Final Cut Pro Legacy › VO Audio Playback Issues FCP 6
  • VO Audio Playback Issues FCP 6
    Posted by Matt Arnold on December 11, 2008 at 2:52 pm
    Running a G5, Dual 2.7, 10.4.11, FCP 6.0.4, Quicktime 7.5.5
    I have a client who is experiencing peculiar audio playback issues in his timeline sequence, when playing back VO he has recorded through a microphone/yamaha mixing desk/line input. The audio appears to have recorded fine as it often plays back without error in the finder AND in other sequences. But the problem returns intermittently during playback in FCP and apart from it being very annoying, it makes the audio unusable and hard to cut with. To be more precise, the audio crackles and stutters and even repeats split second portions of it in playback (ie if speaking the word “stutter” it would sound like “st, stutter”). The source audio file is your standard AIFF, 16-bit Integer (Big Endian), Stereo, 48.000kHz file and is recorded using the VO Tool in FCP. The problem appears to lay in the processing of the file in FCP.
    Any ideas?
    John Fishback replied 17 years, 9 months ago 3 Members · 2 Replies
  • David Bogie
    December 11, 2008 at 3:19 pm
    Is the distortion exacltly in the same places? If so, it’s the media.
    If the distortion migrates each time, it might still be the media. FCP doesn’t process v/o any differently once it is written to disk from RAM.
    Find the file and export it, even if it’s just to the same settings.
    If the exported file exhibits the same issues, it’s the original media, not FCP.
    You can also try simply duplicating the file at the Finder.
    Give us a few more hours as the west coast wakes up. You’ll get some additional or better advice soon.
    bogiesan
  • John Fishback
    December 14, 2008 at 1:09 am
    Did you try an Audio Mixdown?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
