Activity Forums VEGAS Pro vlc says 23.9 fps, vegas says 25
  • vlc says 23.9 fps, vegas says 25
    Posted by Johnny Laty on October 5, 2024 at 5:14 am
    I rendered it to 23.9 and the framerate is off. So I’m guessing vegas is right, and vlc is wrong? Strange cause I thought vlc was accurate with that. Tomorrow I’ll render to 25 and see.
    Hector Vera replied 1 year, 11 months ago 2 Members · 1 Reply
  • Hector Vera
    October 7, 2024 at 3:00 pm
    Not sure whats going on here exactly but it seems to me that when you render a video at 25 fps, it may appear as lower when actually playing it. After all, its kinda like when you have 500 GB of External Drive storage and only 460 something GB is usable since the other 40GB or so runs the system behind it, like if Windows is preinstalled in a Drive marketed at 500 GB.
    Plus why 25 fps if I may ask? Not sure if you are running an SD or HD quality video but if its HD, usually I would run it at 59-60fps whenever I render any of my HD videos for my YouTube channel. I wish you best of luck, try rendering at 30fps to see if VLC runs it at over 25 fps. There are plenty of rendering format options you can choose from in Vegas PRO.
