Activity Forums VEGAS Pro VLC as a recording option for HDMI/USB3 capture devices.. but file capture encoded format..?
  • VLC as a recording option for HDMI/USB3 capture devices.. but file capture encoded format..?
    Posted by Jean-pierre Desrochers on February 19, 2015 at 4:11 pm
    I use VideoLan VLC to record HDMI feed going to
    my Magewell XI100DUSB-HDMI HDMI to USB 3.0 Video Capture Dongle.
    VLC works very well with this dongle and offers
    many file capture encoding formats to be saved (MP4, AVI, MJPEG, etc..). Ok.
    Now I need some advices on what encoding format parameters
    to use with VLC to make an easily ‘importable’ file to use
    in Sony Vegas Pro 13 for editing…
    I just read that BandiCam app can record and save to
    Sony Vegas importable file which would be
    MJPEG video & PCM audio (supposed to be Sony Vegas native import format..)
    but I’d prefer to use VLC as a recording option.
    So far I capture at 1920x1080i on Windows 8.1.
    Any advices on encoding format parameters ??
    J-P Desrochers
    Quebec, Canada
    Andrew Losurdo replied 10 years ago 3 Members · 8 Replies
  • 8 Replies
  • Stephen Mann
    February 20, 2015 at 5:29 pm
    Personally, I would use AVI as it’s only lightly compressed. MPEG and MJPEG are heavily compressed and really a pain to edit.
    I’ve never used VLC as a recorder – let us know how well it works.
    I am not sure of your workflow – does the Magewell dongle just write a file to your HDD? Video in and USB3 out almost says that it wants to make a file, so I don’t see where VLC fits in the equation.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Jean-pierre Desrochers
    February 20, 2015 at 6:36 pm
    Ok,
    Just watch this video about The Magewell dongle:
    https://www.youtube.com/watch?v=_OT0GoALSLM
    When plugged to a suitable USB3 port
    This dongle is shown as a directshow device in the
    PC video and audio devices. No drivers required to work.
    Now I used VLC to use the dongle incoming video.
    So inside VLC I select:
    – Media/Open a capture device
    – Select both XI100DUSB-HDMI for video
    and XI100DUSB-HDMI(audio device) for audio
    – I then select read (preview) or convert to save the incoming video
    to a file.
    The ‘convert’ option brings a wide variety of encoding option
    for tha saved file.. That’s there that I get confused..
    I don’t know what the best settings should be used
    to get the final captured file importable to Vegas Pro..
    Hope this is much understandable.
    What are your file format/settings suggestions for Vegas Pro ?
    J-Pierre
    J-P Desrochers
    Quebec, Canada
    February 20, 2015 at 8:47 pm
    And I forgot to mention:
    You stated:
    >Personally, I would use AVI as it’s only lightly compressed. MPEG and MJPEG >are heavily compressed and really a pain to edit.
    You are right on that.
    That’s the file type I’d like best.
    But since AVI is only a container I still can’t figure
    what to put inside as encoding..
    On other forums some users say they are using
    MPEG-2 or M-JPEG for Vegas compatibility,
    other say MP4 is the way to go for import in Vegas.
    Very confusing !!!
    But again the container’s inside parameters are
    always unknown.
    My video parameters to encode are
    video: 1920x1080i 60fps
    audio: stereo PCM 48khz
    JP
    J-P Desrochers
    Quebec, Canada
  • Stephen Mann
    February 21, 2015 at 10:05 pm
    That’s quite a device. And reasonably priced, too.
    So your only encoder options are MPEG and variations of MPEG?
    Well, since MPEG2 is a delivery format for DVD and MPEG4 is a delivery format for online, that would seem to point to M-JPEG. But I know really little about M-JPEG.
    Have you tried looking at the output file using MediaInfo?
    Steve Mann
    http://www.mmdv.com
    February 22, 2015 at 6:28 pm
    Steve,
    Here are the summaries of 2 captures (4:3 then 16:9) I’ve done
    and read using mediainfo:
    – 10 sec capture on 4:3 Canopus ADVC(firewire)
    capturing to DV AVI using Vegas Pro 13
    General
    Complete name : D:\Dossiers video\Capture general\(Unknown) – Clip 001.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    Commercial name : DV
    File size : 38.3 MiB
    Duration : 10s 544ms
    Overall bit rate mode : Constant
    Overall bit rate : 30.5 Mbps
    TAPE : (Unknown)
    TCOD : 512877365000
    TCDO : 512982803667
    VMAJ : 4
    VMIN : 0
    STAT : 316 0 3.433988 1
    DTIM : 0 0
    Video
    Format : DV
    Codec ID : dvsd
    Codec ID/Hint : Sony
    Bit rate mode : Constant
    Bit rate : 24.4 Mbps
    Encoded bit rate : 28.8 Mbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:1:1
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 2.357
    Time code of first frame : 14:14:47;23
    Time code source : Subcode time code
    Stream size : 36.2 MiB (94%)
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 1
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 1.93 MiB (5%)
    Alignment : Aligned on interleaves
    Interleave, duration : 264 ms (7.90 video frames)
    Interleave, preload duration : 266 ms
    – 10 sec capture on 16:9 Magewell HDMI dongle (USB3)
    capturing to MPG2 using VidBlaster demo
    General
    Complete name : D:\Dossiers video\Capture general\Test Magewell\VidBlaster test Magewell 10 secondes 1920×1080 60fps.mpg
    Format : MPEG-PS
    File size : 6.46 MiB
    Duration : 10s 633ms
    Overall bit rate mode : Variable
    Overall bit rate : 5 093 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=15
    Bit rate mode : Variable
    Bit rate : 4 671 Kbps
    Maximum bit rate : 8 000 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 30.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.075
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    Stream size : 5.92 MiB (92%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Duration : 10s 560ms
    Bit rate : 320 Kbps
    Delay relative to video : -10ms
    Stream size : 413 KiB (6%)
    Comparing both infos can you tell if the MPG2 is too much
    compressed to be used for editing in Vegas Pro 13
    compared to the standard DV AVI capture format Vegas
    uses when capturing ?
    J-Pierre
    J-P Desrochers
    Quebec, Canada
    February 23, 2015 at 7:09 pm
    Steve,
    I just found a program called VMix that seems to do exactly
    what I’m looking for..
    – Recognise the Magewell USB3 dongle device,
    – Capture and save to many possible ‘not too compressed’
    encoding formats.
    The best capture/encoding I found so far would be the following:
    (MediaInfo text dump of a 60sec 1920x1080i 50Mbps bit rate, 48khz PCM audio)
    General
    Complete name : D:\Dossiers video\Capture general\Test Magewell\vmix capture – 23 février 2015 – 01-38-34 AVI-1920×1080 NTSC_2997p MJPEG Encoder DMO 90% compression.avi
    Format : AVI
    File size : 347 MiB
    Duration : 1mn 0s
    Overall bit rate : 47.8 Mbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 1mn 0s
    Bit rate : 46.2 Mbps
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.744
    Stream size : 335 MiB (97%)
    Audio
    Format : PCM
    Codec ID : 1
    Duration : 1mn 0s
    Bit depth : 16 bits
    Stream size : 11.1 MiB (3%)
    Interleave, duration : 20 ms (0.60 video frame)
    Interleave, preload duration : 80 ms
    Other encoding options in Vmix are
    AVI(AVI or MKV)
    MPEG-2 (Adjustable bit rate from 1 to 75mbps)
    WMV
    MP4
    Do you think these above AVI settings are a good compromise
    to save my captured files to be afterward edited in Vegas Pro ?
    Or could they be more compressed and still keep a good quality
    to edit ?
    JP
    J-P Desrochers
    Quebec, Canada
    March 29, 2016 at 3:08 pm
    Steve, did you check my 2 last posts (one year old..)?
    Your reply would be very useful..
    Thanks.
    JP
    J-P Desrochers
    Quebec, Canada
  • Andrew Losurdo
    September 5, 2016 at 2:28 am
    I buy a Seetec HDMI to USB3.0 capture from Alibaba Trade Assurance.
    I think it is a really nice tool.So I would like to share it here.
    -No drivers to install and works with most software on PC and Mac.
    -Allowing live video streaming, webcasting or video conferencing to Skype, Facebook Live, Youtube Live,etc.
    -Can capture various HD video sources with resolutions up to 1920x1200p @ 60fps.
    -Get power from the PC directly.
    -USB3.0, 300-350MB/s throughput and it is compatible with USB 2.0 40MB/s.
    Input Formats:
    Resolutions: 640×480/720×480/720×576/768×576/800×600/1024×768/1280×720/1280×800/1280×960/1280×1024/1368×768/1440×900/1600×1200/1680×1050/1920×1080/1920×1200/640×360/856×480/960×540/1024×576
    Frame Rate: 25/29.97/30/50/59.94/60 fps
    Output Formats:
    The Support of OS
    Windows 7
    Windows 8
    Windows 10
    Windows Server 2008 R2
    Linux (Kernel version 2.6.38 and above)
    OS X (10.8 and above)
    Android
    You can check it on the Alibaba link:
    https://wholesaler.alibaba.com/product-detail/reliable-and-flexible-solutions-multi-source_60483196617.html
    Hope this will help you.
    Andrew
