Activity Forums Adobe After Effects Visualizing Music Beats
  • Visualizing Music Beats
    Posted by Kim Huston on July 16, 2008 at 8:25 pm
    So this is probably a really easy thing to solve, but part of my problem in searching for the answer is not knowing what key words to search.
    Basically, I want to automate or mostly automate an effect to follow the beat of a song. The effect I was going to try it on was Geomancy’s GridSquares. But any example, if they’re all the same or similar would do.
    Kim Huston replied 18 years, 2 months ago 2 Members · 7 Replies
  • 7 Replies
  • Kim Huston
    July 16, 2008 at 8:52 pm
    Oh.. well additionally, how can I use that effect to reveal text?
    I don’t actually know how to use it at all!
  • Todd Gillespie
    July 16, 2008 at 9:02 pm
    Take a look at Trapcode’s SoundKeys
    https://www.trapcode.com/products_soundkeys.html
    for some understanding on how to do this effect. You can attach a sound frequency to about any parameter you want to affect the effect.
    You can probably achieve close to the same effect by using an expression with the audio layer.
    FWIW
    Cheers,
    Todd at UCSB
    Television Production
  • Kim Huston
    July 16, 2008 at 9:15 pm
    Hey cool! I’ll give that a try. Thanks!
  • Kim Huston
    July 16, 2008 at 9:56 pm
    Having watched the tutorial for the Sound Keys, I tried to apply the same technique to getting the GridSquares first to react to the text. So I made the GridSquares effect on a solid and then linked it to an expression of opacity on the text layer. Nothing happened, and I’m guessing it was because I shouldn’t have put the GridSquares effect onto a solid?
  • Kim Huston
    July 16, 2008 at 9:58 pm
    The Expression link gives me this warning:
    After Effects warning: Object of type Layer found where a Number, Array, or Property is needed. Expression Disabled.
    Error occurred at line 0.
    Comp: ‘Comp 1’
    Layer:1 (‘Text’)
    Property: ‘Opacity’
  • Todd Gillespie
    July 16, 2008 at 10:04 pm
    If you haven’t already, please take a look at this tutorial
    https://www.trapcode.com/in_action/soundkeys_intro.html
    It should give you all the info you’ll need to get started.
    Good Luck,
    Todd at UCSB
  • Kim Huston
    July 18, 2008 at 2:25 pm
    That’s the tutorial I was talking about a few posts ago.
