Activity › Forums › Apple Final Cut Pro Legacy › visual hiccup on transtions between stills
  • visual hiccup on transtions between stills
    Posted by Peter Dewit on March 13, 2007 at 9:38 pm
    Ok i’m working with a bunch of still and putting transititonsbetween them(a standard cross dissolve. After rendering the effects I noticed a little problem. When the transition starts the picture shifts postion on the monitor ever so slightly. It’s not a huge shift but it is pretty distracting. What in my render settings could be causing this?
    Peter Dewit replied 19 years, 6 months ago 4 Members · 4 Replies
  • Don Greening
    March 13, 2007 at 10:38 pm
    [Peterd] “What in my render settings could be causing this?”
    This happens all the time to me before the effect is rendered, but not after. Just a reminder to make sure that what you’re viewing really IS rendered. If you’re seeing the problem after rendering then I’m not sure what it might be. If this has just started happening lately, try running FCP Recue and do the “trashing preferences” thing.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
  • Chris Tompkins
    March 13, 2007 at 11:28 pm
    Make sure you render preview and render full
  • Jeremy Garchow
    March 14, 2007 at 3:38 am
    [Chris] “Make sure you render preview and render full”
    Meaning, go into your sequence > render all and sequence > render selection menus and make sure that all the options have a chekc mark next to them, especially the ‘full’ option. After doing that, hit option-r to render the whole timeline.
    Jeremy
  • Peter Dewit
    March 14, 2007 at 1:27 pm
    that did the trick. thanks!
