Activity Forums Panasonic Cameras Vista-Quicktime-p2Raw files
  • Vista-Quicktime-p2Raw files
    Posted by Richman’sgrits on May 11, 2007 at 5:14 pm
    I have a project files from a MACOSX/FinalCut Pro Render machine, rendered at:
    HD 960×720 23.98 fps
    DVC Pro HD 720P60 Compression (5.9 MB/sec)
    Shot on a Panasonic AVX200.
    I imported the files into AE and all I see is a white screen. Audio stream is present and plays back. File sizes are roughly 250MB each.
    I tried to playback the files in QT 7.1.6 and the application hangs and eventually stops responding.
    Just wondering if anyone has ventured into Vista as a work platform and seen this problem.
    Thanks in advance,
    J
    Richman’sgrits replied 19 years, 3 months ago 4 Members · 4 Replies
  • Hhv_pro
    May 11, 2007 at 8:51 pm
    I believe it happens when you are missing the necessary video decompressor(codec). Try to install the free P2 Viewer from panasonic and see if it helps.
  • Marcus Van bavel
    May 11, 2007 at 10:55 pm
    You’ll need the DVCPROHD decoder for quicktime windows. Get it
    at https://dvfilm.com/raylight/decoder
  • Barry Green
    May 12, 2007 at 2:45 pm
    [hhv_pro] “I believe it happens when you are missing the necessary video decompressor(codec). Try to install the free P2 Viewer from panasonic and see if it helps.”
    That won’t help; Apple refuses to implement DVCPRO-HD support on the Windows version of Quicktime. What you need to do is what mvb said — get the dvfilm.com Quicktime Decoder; it’ll add the necessary missing support.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Richman’sgrits
    May 12, 2007 at 8:38 pm
    Well, I tried all the suggestions and still I see a white screen and hear audio. I updated Vista and QuickTime and bought QT Pro 7, but no change. Not sure what else to do. I am Googling my brains out trying to find a solution. I’ll let you know if I find anything that works.
    Thanks for the help.
    J
