Activity › Forums › Avid Media Composer › Vista or XP
  • Vista or XP
    Posted by Jimmy Mounts on February 8, 2009 at 10:18 pm
    I just bought a computer for my Avid, After Effects, and Photo Shop. The computer came with Vista Home and to use Avid I will have to either upgrade to Vista Business or switch to XP Professional.
    My first question is, can I upload XP Professional on a computer that already has Vista?
    Secondly, which operating system would be better for editing (avid, after effects, etc) XP or Vista?? I’ve read several different reviews online and don’t know what to do.
    Michael Phillips replied 17 years, 7 months ago 5 Members · 6 Replies
  • Michael Phillips
    February 8, 2009 at 10:33 pm
    if looking at Vista I would consider Vista 64 since it will give you access to lots more RAM for the applications.
    Michael
    Michael Phillips
  • Jimmy Mounts
    February 9, 2009 at 4:04 am
    So would you recommend vista 64 bit over xp pro??
  • Anton Lee
    February 9, 2009 at 10:18 am
    To be honest, the best result I’ve had so far is running on XP x64 pro. Has the memory benefits of the 64-bit operating system and the stability of xp.
  • Jon Zanone
    February 9, 2009 at 12:56 pm
    One more thing – if you use Sorenson, it won’t work with Vista. We recently had 7 Vista Media Composers re-imaged to XP because of that as well as some other quirky things. XP works well with Avid, Sorenson, AE, PShop… Vista is going away to be replace by Windows 7…
    Jon
    “Jamming our heads full of figures and angles
    And telling us stuff that we already know”
    Willie The Wandering Gypsy & Me
    Billy Joe Shaver
  • Michael Hancock
    February 9, 2009 at 3:03 pm
    [Anton Lee] “To be honest, the best result I’ve had so far is running on XP x64 pro. Has the memory benefits of the 64-bit operating system and the stability of xp.”
    Except Media Composer isn’t certified to run on any 64-bit version of XP, so you’re taking a pretty big risk by doing it. It may run perfectly well, but as soon as you hit a problem you’ll be out of luck with Tech Support because you’re running a non-approved OS.
    Michael
  • Michael Phillips
    February 9, 2009 at 7:40 pm
    Media Compsoer 3.x is suported on Vista 64 which is why I offered it as an option in the first place.
    Michael
    Michael Phillips
