Activity Forums Boris FX Particle Illusion Vista / 64 bit issues?
  • Vista / 64 bit issues?
    Posted by Donovan Werts on July 19, 2008 at 12:01 am
    Hi, I want to buy a new computer. It will have Vista and a 64 bit system (not sure what that means exactly) and I was told that some software might not work with 64 bit systems. Does Particle Illusion have issues? I already use, and love, the software. Not wanting to get a computer that it won’t be compatible with. Thanks In Advance, Donovan
    Alan Lorence replied 18 years ago 3 Members · 5 Replies
  • Leonard Rivera
    August 2, 2008 at 4:08 pm
    Well, I just setup my Vista 64 bit and particle illusion does not seem to work at all. I even try running it in Windows XP compt. mode with the same results. I sent an email to Alan inthe hopes that this can be addressed.
  • Alan Lorence
    August 2, 2008 at 6:36 pm
    I did not receive the email (yet). You must be running 3.0.2 or later.
    https://www.wondertouch.com/default.asp?loadContent=updates.asp
    Alan.
    http://www.wondertouch.com
  • Leonard Rivera
    August 2, 2008 at 9:32 pm
    Thanks ALAN! Worked like a charm. Not sure why you did get my email. Doesn’t matter now, you fixed right fast. Thanks agan, all the best.
    Lenny
  • Leonard Rivera
    August 3, 2008 at 7:15 pm
    BTW – I did get undeliverable finally – I sent it to alan@egz.com
    This message was created automatically by mail delivery software.
    A message that you sent has not yet been delivered to one or more of
    its recipients after 27 hours.
    The message has not yet been delivered to the following addresses:
    host egz.com[216.8.179.23]:
    connection to mail exchanger failed with timeout
  • Alan Lorence
    August 14, 2008 at 7:58 pm
    Did you have to do anything special to get 3.0.3 working on Vista 64? Is there some compatibility setting (or whatever) that is required?
    Alan.
