Activity › Forums › Apple Final Cut Pro Legacy › visibility on but clip not visible in viewer.
  • visibility on but clip not visible in viewer.
    Posted by Maura Cunningham on September 30, 2008 at 10:31 am
    Hi there!
    A couple of weeks ago I burned out a project – no bother – which now needs some changes made to it, but there is now a strange glitch at the start of the sequence. I have ten video tracks to open with, with video tracks laid on shapes in composite mode luma. The thing is none of them – from track 3 upwards – are visible in the canvas at playback. All tracks are turned on – and further down the project similar elements in luma mode on the same ‘problem’ tracks playback fine, it is only the first 20secs that are causing the problem. When I double click on one of these “invisible” clips they show up correctly in the viewer, but they have that dulled out look of “turned off” tracks in the timeline. I can re-cut easily enough but I don’t like not knowing…. Any ideas??
    Thanks in advance -this is one great forum!
    Maura Cunningham replied 18 years ago 2 Members · 2 Replies
  • Steven Gonzales
    September 30, 2008 at 1:49 pm
    Select one of the dulled out tracks, and see if clip enable is checked under the Modify menu, or control-click on the clip to see if clip enable is checked in the contextual menu.
  • Maura Cunningham
    September 30, 2008 at 2:06 pm
    And that was it…Thanks Steven, hadn’t come across that before – always the simple things!
