virtual midi to link vegas to acid
Posted by Robert Dupper on November 5, 2009 at 8:32 amHello, esteemed fellow vegans,
i’ve been looking for a way to sync vegas to acid.
is that possible at all?
i came across loopbe1 at https://nerds.de/en/loopbe1.html, a virtual midi driver.
would that help in any way?thank you in advance.
kind regards,robert
Robert Dupper replied 16 years, 10 months ago 4 Members · 8 Replies -
Danny Hays
November 5, 2009 at 8:57 amhttps://www.sonymediasoftware.com/dl/dl.aspx?dwnid=77
Check this virtual midi router out. Danny -
Robert Dupper
November 5, 2009 at 9:44 amHi Danny,
thanks for your superfast reply!
i did checked it out, but i cannot get it to work.
have you tried it?robert
robert dupper
sony vegas
after effects
photoshop
logic
cubase -
John Rofrano
November 5, 2009 at 1:44 pmTry following my tutorial:
Installing the Virtual MIDI Router
on my web site.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Robert Dupper
November 5, 2009 at 7:58 pmThanks, John,
i tried installing it, but it says it won’t install on my 64 bit vista system. bummer.
i did manage to install loopbe1 virtual midi.
it shows up in both vegas and acid, but i still don’t seem to be able to get them to sync up. i must have tried every possible combination of settings in both programs.would you please be so kind to explain to me what the settings should be in both vegas and acid?
-or do i really need to get back to xp?
robert dupper
sony vegas
after effects
photoshop
logic
cubase -
John Rofrano
November 5, 2009 at 8:12 pm> i tried installing it, but it says it won’t install on my 64 bit vista system. bummer.
Yea, I never tried it on Vista 64 so I’m not surprised that it doesn’t work. It wasn’t designed for XP either so it was a stretch that it worked there (it’s a Windows NT driver!)
ACID likes to be the master so are you setting up Vegas to be the slave? What versions of ACID and Vegas? With the multi-track audio capabilities of ACID Pro 7.0 I can’t see any reason for needing Vegas so what exactly are you trying to do?
~jr
Robert Dupper
November 5, 2009 at 8:34 pmwell, i am a video editor who likes to make the music as well.
it would be ideal for me to be able to make the music and sketch the video edit without having to render and bounce back and forth.
but now i am starting to think i got this whole midi-sync thing wrong.
my wish is to have acid and vegas in a sort of rewire mode.robert dupper
sony vegas
after effects
photoshop
logic
cubase -
Dave Brandt
November 7, 2009 at 12:40 amHi
Did you try https://www.midiox.com ?
I’m not sure it works in 64bit, but I did have it going in 32bit vista. I had nuendo slaving to vegas, I was able to use nuendo to play the audio multitrack in perfect sync with vegas By using this technique. Once your virtual midi driver is working it’s straight forward enough to slave them.
You could always go hardware too if you buy a cheap midi interface with 2 in 2 out, just loop a cable and assign the correct ports and bob’s your uncle.
Dave
Robert Dupper
November 7, 2009 at 9:01 amhi, dave,
i will try that.
first the software, then the hardware option.
this will be in a few days, though.thanks a lot.
have a nice weekend!r.
robert dupper
sony vegas
after effects
photoshop
logic
