Activity Forums Adobe After Effects Virtual Memory Help Please!
  • Virtual Memory Help Please!
    Posted by Mark Dalzell on March 24, 2009 at 7:37 pm
    Error messgage:
    “Your system is low on virtual memory. To ensure that Windows runs
    properly, increase the size of your virtual memory paging file”.
    What do you recommend the virtual memory be set to?
    I’m using AE CS4.
    Mark Dalzell
    System Specs:
    VisionDAW 4U 8-Core Xeon Workstation
    2 Intel QUAD-Core Xeon 5365-3.0GHz, 8MB, 1333MHz Processors
    16GB 667MHz Fully Buffered Server Memory Modules (2x2GB)
    Microsoft® Windows® XP Professional x64 Edition
    WDC 250GB, Ultra ATA100, 7200 rpm, 8MG Buffer Main OS HD
    MOTU 24 I/O (main) / MOTU 2408mk3 (slave)
    2 WDC 750GB, SATA II, 7200 rpm, 16MG Buffer HD (Samples)
    Plexor PX-800A 18X Dbl. Layer DVD+/-RW Optical Drive
    Front Panel USB Acess
    Integrated FireWire (1394a) interface
    Thermaltake Toughpower 850W Power Supply
    Dual ESATA Bracket
    2 WWDC 750GB, SATA II, 7200 RPM, 16MB Buffer HD (Raid 0)
    3xUAD1 Universal Audio Cards
    EVGA NVIDIA GeForce 9600GT, 512MB,
    PCI-Express, DUAL-DVI Video Card
    Dual 25.5″ Samsung 2693HM LCD HD Monitors
    Mark Dalzell replied 17 years, 6 months ago 3 Members · 3 Replies
  • Juan Torres
    March 24, 2009 at 8:39 pm
    I actually created a 10 gig partition and use it as ram cache for AE memory. You can set your ram cach in the edit/preferences, I have 4 gigs of ram anda quad core, also go to your secret menu by holding shift and clicking edit, scroll down to preferences and click it then let go of shift. You will now see a secret tab at the very bottom, you can set the amount of frames that render with an auto purge to keep continual rendering. Mine is set to 0. Other than that you can go to Edit/Purge and manually do it every time you run into the problem.
    Keep It Real
  • Chris Wright
    March 24, 2009 at 10:44 pm
    virtual mem should be set on diff hard drive and also diff motherboard cable than Windows OS, a good rule of thumb is min 1.5x ram, max 3x ram, although system managed size is supposed to increase automatically if needed, you might be low on hard drive space. right click system properties-advanced to see where it saves the virtual swap file and manually enter number/change to another drive as needed.
  • Mark Dalzell
    March 25, 2009 at 10:32 pm
    Hi Juan,
    Thanks for the info. I checked out the “scret menu” and here’s how
    it’s set.
    Disable Layer Cache is NOT checked.
    Purge every 0 frames…
    Ignore Sequence Rendering Errors is NOT checked.
    Are these set correctly?
    Best.
    Mark
