Activity Forums Adobe Premiere Pro Virtual KEM? Editing sequence into another sequence without laying in a nest?
  • Virtual KEM? Editing sequence into another sequence without laying in a nest?
    Posted by Andy Field on June 22, 2013 at 11:01 pm
    PP CC has new option to edit a sequence into another sequence (great if you create a reel of clips to skim through and select and edit)
    It should work as advertised, but when i turn the feature on (upper left hand corner of timeline) it will lay the audio in, but it creates a SLUG where the video should go.
    Anyone encounter this…am i doing it wrong …missing something? is this a bug? Thanks
    Andy Field FieldVision Productions, N Bethesda, Maryland
    Andy Field replied 12 years, 11 months ago 1 Member · 1 Reply
  • Andy Field
    June 22, 2013 at 11:18 pm
    OK – solved my own problem – turns out I’d put a slug on the KEM sequence on Video track two to use for a time code burn…..and you must specify which video track you want to insert into the new sequence…..as Emily Latella used to say “never mind”
    Andy Field
    N. Bethesda, Maryland 20852
