Activity Forums Adobe After Effects Virtual clone via expressions+script? // Auto-pickwhip dozens of parameters?
  • Virtual clone via expressions+script? // Auto-pickwhip dozens of parameters?
    Posted by Eric Chard on July 21, 2013 at 1:57 am
    There’s various ways around my particular need here, BUT in the interest of curiosity:
    Is there a script that will essentially CLONE a Text layer, and have the clone automagically (via expressions) ape all the settings on the original layer? IOW, this script would Duplicate a Text layer, and automatically set pickwhip-type expressions for all the parameters.
    The user could then disable those parameters s/he doesn’t want slaved– otherwise you’d just use a pre-comp.
    My feeling here is it’s easier to DISABLE a few parameters rather than set up the dozens of slave parameters.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Eric Chard replied 13 years, 1 month ago 2 Members · 3 Replies
  • Walter Soyka
    July 22, 2013 at 12:52 pm
    Paul Tuersley’s pt_TextEdit script is not exactly what you described, but it may do what you need:
    https://www.aescripts.com/pt_textedit/
    Walter Soyka
  • Eric Chard
    July 22, 2013 at 9:59 pm
    Nahhh, I’m looking more for a slave/clone situation, where a layer will imitate ALL the parameters of the master, except for those you disable (on the premise that it’s easier to disable a few than link dozens).
    For this particular task I needed one text layer to have a fill, and an identical one to have NO fill.
    If this were being art-directed, NO DOUBT the ‘creative’ would repeatedly change font, kerning, etc, which makes just duplicating the layer impossible. It would be a huge PITA. But a slave layer would follow everything BUT the Fill setting, so you could tweek to your heart’s content.
    Hmmmm…. I think you could just set this up ONCE as an AEP, and IMPORT the AEP to get this particular arrangement of layers. Then you just need access to that AEP.
  • Eric Chard
    July 22, 2013 at 10:04 pm
    Maybe not: since, for example, the FONT is not an animatable property, you cannot simply pickwhip it.
