Activity Forums Adobe Premiere Pro Virgin Clips on timeline needing to be rendered.
  • Virgin Clips on timeline needing to be rendered.
    Posted by Steve Mac kenzie on September 24, 2006 at 7:32 pm
    I built a sequence with 2 cameras and synced them up. At some point once I starting cutting I noticed that everything on Video layer 2 is saying that it needs rendering. I checked to see if the clips motion parameters had been accidentally bumped a little bit but they are alright. I also checked to see if I accidentally put an effect on the whole layer and the answer is no. I even tried to move the longer video 1 clip and put it on top of the video 2 clip and the video 2 clip is still showing that it needs rendering even from under the video 1 clip. I did try to matchframe a piece of video 1 and lay it up on 2 and them 3 and it wants it to be rendered.
    I had a seperate safety sequence and there was no rendering issue so I razored it and tried to replace the offending clips and it is showing it needs to be rendered so then I reversed the process and put the edited part on the beginning of the safety sequence and guess what render time. I hope there has got to be an answer on how to solve this from someone out there.
    Steve
    Thank You for your input!
    Steve Mac kenzie replied 19 years, 11 months ago 1 Member · 1 Reply
  • Steve Mac kenzie
    September 24, 2006 at 9:08 pm
    Solved it, the vid card defaulted to a setting.
