Activity Forums Maxon Cinema 4D villa of cubes
  • villa of cubes
    Posted by Trev on March 16, 2007 at 5:45 pm
    hi, ive built a spanish villa and i want to slice it up into a big block of cubes and animate them seperatly. I’ve tried to boole the villa from a block of 100 cubes which works but when you make it editable all the insides of the cubes seperate but all the outside surfaces are one object. ive tried importing the vila as a whole object with out caps and it does something similer. i also want to animate the seperate bits in a stream through the air, so if anyone has any sugestions of easy ways to do that, that would be great thanks for any help trev
    Trev replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
