Activity › Forums › Panasonic Cameras › Vignetting on one side
  • Vignetting on one side
    Posted by Kian Mckellar on December 14, 2011 at 8:20 pm
    I was filming something recently and I noticed some vignetting on the ride top and bottom corners. This was using the AF-100 with the 14-140mm lens. Later I switched out the lens with a 50-250mm and still had the same effect while the 14-140mm did not have this effect on another AF-100. So fairly certain it is the camera.
    When I tried it hours later it disappeared.
    Anyone know possible reasons for this and if I should send it in? Only three months old.
    Kian Mckellar replied 14 years, 9 months ago 3 Members · 3 Replies
  • Joe Barta iv
    December 15, 2011 at 7:32 pm
    Sometimes the ND Filter wheel will get bumped and be turned just slightly creating the same effect. I’ve had it happen a couple of times when changing lenses on the AF100.
    Joe
    Bars & Tone
    SALUTE!
  • Matthew Romanis
    December 17, 2011 at 2:27 am
    Agreed, the ND filter wheel is the likely culprit.
    Especially if it was not there a while later.
  • Kian Mckellar
    December 23, 2011 at 5:33 pm
    Gotcha. Thanks for the help. Ironically I asked my boss and she said the same thing. Then she found my post and your answers she forwarded them to me as a “see, I was right.” Well played boss, well played.
