Activity Forums Maxon Cinema 4D Viewport locking up
  • Viewport locking up
    Posted by Josh Earle on April 16, 2025 at 7:06 am
    Usually when doing something a little demanding like dynamics, but sometimes just orbiting around with camera. C4D will freeze up for about 10 seconds, then will seem to be working again except that the viewports are frozen. All functionality seems to still be there but obviously cannot see what Im doing.
    Anyone know what causes this?
    using 2025.1.2
    Judy Murphy replied 10 months, 1 week ago 4 Members · 5 Replies
  • Kouraib Abdmalek
    April 16, 2025 at 8:04 am
    Hi Josh,
    If freezing happens after rendering, it is likely that the problem is with Redshift. Make sure that it is updated. Some users found problems with GPU-Render, such as Redshift and Octane with the 2025 version, unlike CPU-Render, such as Corona, which works well on this version, so many still prefer to work on 2024. Or you should install the latest updates of 2025 because they fix some of the bugs every time.
    Hope this is helpful for you.
  • Josh Earle
    April 16, 2025 at 10:04 am
    Nope, not doing any rendering nor do I have redshift open. Simply C4D locking up and then becoming functional again but the viewports are frozen. No way around it but a restart. It happens quite often. Anyone else having this problem?
  • Alex Todorov
    April 17, 2025 at 7:13 am
    It may can if you turn of Snapping. Try to turn off the snapping
  • Kouraib Abdmalek
    April 21, 2025 at 7:45 am
    If so, could you please send me one of the files that is causing the viewport freezing so I can test it in my version to see if the problem is with your project settings or if there is a bug in your version. Therefore, you should contact Maxon’s support team to resolve the issue.
  • Judy Murphy
    November 5, 2025 at 12:03 pm
    I think you should update your GPU drivers (clean install) or disable or remove conflicting apps (e.g., Insta360Stitcher).
