Activity Forums Apple Final Cut Pro Viewing Time Remapped clips or effects on Project timeline
  • Viewing Time Remapped clips or effects on Project timeline
    Posted by Jordan Mena on November 15, 2013 at 8:01 pm
    Is there a way yet to be able to visually see if a clip has been time remapped or has an effect on it at a glance? I noticed after I speed up or slow down a clip after I close the remap bar if I open it again it makes the clip go back to 100%. unless I use Command+R. I don’t want to accidentally undo a speed change by mistake.
    I liked the button in FCP7 that raised the clips up on the timeline so I could visually see which clips had effects or speed changes. It should be in X no?
    thanks!
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
    Bret Williams replied 12 years, 9 months ago 3 Members · 2 Replies
  • James Cude
    November 15, 2013 at 8:15 pm
    Select All Clips- then Command R for Show/Hide Retime Editor.
  • Bret Williams
    November 15, 2013 at 8:59 pm
    It shouldn’t be going back to 100% unless you specify for it to.
