Activity Forums Apple Final Cut Pro viewing source timecode of clip on timeline (project in fcp x)
  • viewing source timecode of clip on timeline (project in fcp x)
    Posted by Michael Williams on August 4, 2012 at 9:56 pm
    Just cutting my teeth on FCP X. This seems very basic, but I don’t see how to do a match frame to my source video or at least view the source timecode of my footage that is already on my timeline. would appreciate any help.
    thanks,
    mike
    Alban Egger replied 13 years, 12 months ago 4 Members · 4 Replies
  • Michael Hofeldt
    August 4, 2012 at 10:26 pm
    The command for match frame is SHIFT+F, which reveals the clip and selection range in the browser.
    Also, if you skim over your clip in the timeline with the trim tool selected (instead of the selection tool) you will see the clip timecode. My trick is to hold down T without letting go to temporarily engage the trim tool. Blade and Range tool do the same thing
    Check out Richard Taylor’s Tips. that’s where I discovered the above.
  • Jari Innanen
    August 4, 2012 at 10:43 pm
    Try the “Clip Skimming”-command under the View menu. Should show you the TC if there is one.
  • Michael Williams
    August 4, 2012 at 10:50 pm
    big thanks!
  • Alban Egger
    August 7, 2012 at 6:41 am
    CMD-S turns on clip-skimming as Jari suggests. This way you can “kind-of-solo” any clip any time and also see its timecode.
