Activity › Forums › Apple Final Cut Pro › Viewing source material at higher speed
  • Viewing source material at higher speed
    Posted by Sascha Engel on March 27, 2014 at 8:25 am
    Hi Everyone,
    Follow thought/question: If I have to watch tons of footage, in which I do also have to understand the content, watching in Real Time takes ages.
    Now, when I watch tutorials e.g. in QT 7, I can set the speed of playback to 1,5x which still keeps everything totally understandable, but cuts the time by 30%.
    If I use JKL keys in FCPX, it doubles the speed, which is fine for visuals, but in case I need to understand content, it’s slightly too fast.
    Any way, to get X to playback at 1,5x regular speed – or something in that area?
    If not, it definitely should be build into the next version.
    Also something I REALLY miss in FCPX!!!!: If you set in & outs, and you mess it up for whatever reason, in FCP7 you could get those in&outs back by undo.
    Not so in X. Would be great if you could.
    Thanx.
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Sascha Engel replied 12 years, 6 months ago 2 Members · 2 Replies
  • Nick Toth
    March 27, 2014 at 1:42 pm
    You can drop the footage into a project on the primary storyline and re-time it to 150% with ripple enabled.
    anickt
  • Sascha Engel
    March 28, 2014 at 9:06 am
    Simple, but effective, yes. Good one. And then match frame to source clip so you can Favourite the part.
    What you mean by “with Ripple”?
    Greetings,
    Sascha Engel
