Activity › Forums › Apple Final Cut Pro › Viewing selected ‘range’. Or view in to out in viewer
  • Viewing selected ‘range’. Or view in to out in viewer
    Posted by James Bayliss-smith on July 14, 2011 at 4:40 am
    This is sending me crazy. So I’ve selected a ‘range’ of a clip in the browser and I’m about to overwrite it to the timeline. Now I want to view the range I’ve just selected before I put it onto the timeline. In FCP7 I would just hit up (I think it is called previous edit) presuming I’m in the canvas and the play head would jump to the in point and I could just hit space bar and see the clip that I just selected before I used it but I can’t work out how to do this quickly in X? I’ve tried hitting ; which is previous edit but it just extends the range to the begginning o fth eclip losing my inpoint? I’m sure this is very simple but I can’t work it out?
    Ray Wang replied 15 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Brendan Gibbons
    July 14, 2011 at 4:48 am
    I think the same FCP 7 shortcut here applies to X. Shift + I to jump to your in point.
    Cheers,
    Brendan
  • James Bayliss-smith
    July 14, 2011 at 4:51 am
    Thanks Brendan but that doesn’t work
  • Brendan Gibbons
    July 14, 2011 at 5:46 am
    I think we are talking about the same thing?
    You’ve marked a selection in your clip in browser, now you want to jump to the IN point and playback before editing to timeline?
    Shift + i works for me, jumps to selection in point. Shift + O jumps to out point.
    Have a look in the “Mark” menu at the top, “GOTO” submenu, selection Start, and Selection End.
    Cheers,
    Brendan
  • Mark Morache
    July 14, 2011 at 5:55 am
    Shift I and Shift O work for me too.
    Also, just hit the forward slash key /
    It plays the selection from in to out. Super simple.
    I’m calling it FCX. They took the “pro” out, so I will too.
    I’ll reconsider after the first upgrade.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    blogging at https://fcpx.wordpress.com
  • Ray Wang
    July 14, 2011 at 5:58 am
    Pressing backslash will automatically play from the beginning of the selection in the events.
    1. Select in / out points in the event viewer.
    2. Press “/” to playback (it will automatically play from beginning of the range to the end)
    3. Cmd+L to toggle looping (or View menu > Playback > Loop Playback)
    Ray
  • Fabien Daguerre
    July 14, 2011 at 7:03 am
    I may be wrong, but I think the question is about playing selection in the timeline, not in the event browser.
    I’m not comfortable either in selecting areas on the timeline, not on a clip.
  • Ray Wang
    July 14, 2011 at 10:39 am
    If it is on the timeline, you can use either the range selection tool (“R”) or define precisely using “I” and “O” keys in the timeline.
    Pressing “/” plays back the range.
    Ray
  • Ray Wang
    July 14, 2011 at 10:45 am
    As Brendan says, Shift-I, Shift-O moves the playhead to In / Out points.
    But pressing “/” will play from the In point.
    The right section has to be highlighted. i.e. if you want to play in Event (cmd+1), Timeline (cmd+3).
    Ray
