Activity Forums Panasonic Cameras Viewing P2 on hard drive
  • Viewing P2 on hard drive
    Posted by Kearney Buskirk on February 9, 2006 at 11:05 pm
    Hi Folks
    My basic workflow: unload the P2 cards onto my Windows XP laptop and later import these folders into FCP 5. But during the shoot, I would like to be able to playback earlier shots.
    So, once P2 Contents and single file are copied from the card onto my hard drive (and put into a folder), can it be played by the P2 viewer app? If so, how?
    Any instructions anywhere for the P2 viewer app? What’s a virtual P2 card?
    Thanks for your attention and any help.
    Kearney Buskirk
    Barry Green replied 20 years, 7 months ago 2 Members · 3 Replies
  • Barry Green
    February 10, 2006 at 8:28 am
    [Kearney Buskirk]
    Your questions are linked. Yes you can play it back in the P2 viewer app, by using the footage as a virtual P2 card. Once you point the P2 Viewer at the folder where you copied the footage, that folder becomes a “virtual” P2 card, and the Viewer program can play that footage back.
    I don’t know if there’s any documentation available for the program; I kind of had to poke around with it to figure it out. You can go to the Tools menu and choose “setting virtual P2 cards”, which will bring up a dialog box; one of the options will let you navigate to a directory and choose it. Once you do that, you’ve registered that directory as a virtual card. Then in the left side window you can tell it to display the secondary bin as “all virtual p2 cards”, and all your hard disk clips will show up in that window.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Kearney Buskirk
    February 10, 2006 at 4:33 pm
    [Barry Green] “You can go to the Tools menu and choose “setting virtual P2 cards”, which will bring up a dialog box; one of the options will let you navigate to a directory and choose it”
    I couldn’t figure out which option takes me to a directory, I’ll keep playing with it.
    Kearney Buskirk
  • Barry Green
    February 10, 2006 at 8:30 pm
    There’s a row of icons in the upper right, and one of them is a red “X” which removes a directory. Well, to the left of that red “X” is a weird dashed-outline box… that’s the one that lets you add a directory.
