Activity Forums Adobe After Effects Viewing on Ext. Monitor
  • Viewing on Ext. Monitor
    Posted by Justin Skotarczyk on September 8, 2008 at 3:36 pm
    I am trying to get my AE/FCP room up and running at a new company with no engineering dept. (yikes)
    I’m running a Mac Pro system with 2x3GHZ Quad-Core Intel Xeon Processors, 4GB RAM, AJA Kona 3 card, and an external 2TB RAID.
    When I set AE up to be viewable on external monitors running through an AJA Kona card, my RAM previews suffer immensely, providing jittery, non-realtime playback.
    What am I doing wrong here?
    Justin Skotarczyk
    Designer/VFX Artist
    Mosa
    Royal Oak, MI
    Justin Skotarczyk replied 17 years, 12 months ago 3 Members · 3 Replies
  • Kevin Camp
    September 8, 2008 at 4:13 pm
    i have a mac pro and an sd decklink card, and when realtime playback issues i try setting the output quality in the preview settings from more accurate to faster and it usually helps. i assume you have a similar setting for your hardware since it is an ae preference.
    for instance, i can work in the hdv 720 preset if the frame rate is 29.97 and have no issues with realtime playback to the sd broadcast monitor, but if i up the frame rate to 59.94, i can’t get realtime playback without setting the output quality to faster.
    i remember having similar problems with sd widescreen comps too, i can’t remember what my magic formula was for getting those to work, it may have only been a problem working with the sd widescreen square pixel comp, but changing that to an anamorphic comp setting helped, or maybe it was just the output quality setting…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • David Coiffier
    September 8, 2008 at 11:14 pm
    Hi Justin,
    You’re doing nothing wrong. The jitter is from the way comp picture is sent to the Kona3.
    At every frame, when ram previewing, AE sends a picture to the video board. This is not a movie file that it sent, but a single frame…every frame. This is something like trying to drive fast, but with a need to stop every 10 meters…Sending pictures the Kona board just breaks up the ram preview, causing sluggish frame rate.
    The preview option is more something like a handy feature, when color timing, or anything that doesn’t require real time. Use Kona preview only when needed, or if you prefer : turn it off when you need real time preview.
  • Justin Skotarczyk
    September 9, 2008 at 4:16 pm
    David,
    Thank you for that explanation. That makes much more sense to me!
    Justin Skotarczyk
    Designer/VFX Artist
    Mosa
    Royal Oak, MI
