Activity Forums Adobe After Effects viewing objects in no mans land
  • viewing objects in no mans land
    Posted by Al on June 15, 2006 at 7:28 am
    i’ve never found a workaround for this; and am wondering if someone has one, or if AE is looking to improve this in the future–>
    when i’m working in a 3D space, camera moving all over the shop, my viewport is limited to the size of my comp, and any layers outside of what i am viewing are wireframe.
    i’d like to operate as smoke/flint do, in that regardless of your comp size/position of camera –> you are able to see all your layers in your 3D space, outside of your viewport.
    i realise i can make my comp temporarily bigger, or set up different views, but it’s messy.
    anyone have any thoughts before i send off a suggestion to the friendly adobe crew?
    Mike Clasby replied 20 years, 3 months ago 3 Members · 3 Replies
  • Mylenium
    June 15, 2006 at 7:42 am
    Nope, there’s no way around this. A feature request to Adobe would be the way to go. personally I don’t find it too important but then again as a long time 3D artist I would do the “serious” stuff in a 3D program… ;o)
    Mylenium
    [Pour Myl
  • Al
    June 15, 2006 at 7:53 am
    alas; and then what for the long time faux 3D artists?! 🙂
  • Mike Clasby
    June 15, 2006 at 4:07 pm
    Here’s a wrok-around (or limp-around).
    Add another camera, Camera 2, drag it below your Active Camera (assuming you have a camera 1 already).
    Windows > Workplace > Two Camera View
    Set the second view to Camera 2. Select Camera 2, then with the “Track Z Camera Tool” back off until you can see all your layers.
    On AE 6.5 when I ram preview, I don’t see the movement of the layers in View 2 (the one with Camera 2 backed off), but when I scrub the time line I get all movemnet in both views (both cameras, one in each view).
