Activity Forums Apple Final Cut Pro Legacy viewing mov. files shot on an XD
  • viewing mov. files shot on an XD
    Posted by Graeme Mcmahon on August 1, 2007 at 8:31 am
    Hello All,
    I am a cameraman, so my understanding of FCP is rather limited.
    I am cutting a new reel. Footage I have shot on the sony XD, I cannot view the files. I got the mov. files from the production house, I can import them, but when I go to view them in FCP, I only have a white box in the viewer, I cannot view them through quicktime either (I can only see them through VLC player).
    Mov. files I have converted from the HVX 202 do not have problems either.
    2nd problem, every 2nd or 3rd time I open FCP it won’t open. I have to reinstall the program in order for it to open again.
    I hope I gave adequate information.
    Thank you all,
    Mark Maness replied 19 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
  • Michael Gissing
    August 1, 2007 at 8:42 am
    I suspect the codec for the QT file is not in your FCP or Quicktime. Did the production house tell you what codec the QT file was?
    Did you get an error message in Quicktime?
    Also it will help to fill in your setup and FCP version details in your profile or in the question.
  • Tad Newberry
    August 1, 2007 at 9:02 am
    Hi G,
    I’m new to XDCam myself, and am currently cutting a show with footage i shot with that format last week. As far as i know, the only way you can import the XDcam footage into FCP is to use “XDCam Transfer” available for free on the web. From my understanding, it imports as well as converts the XDCam files into usable files within FCP. depending on what hardware and software you are using, here is a link that will give you some options as to what to download…
    https://bssc.sel.sony.com/BroadcastandBusiness/markets/10014/xdcamDownload.shtml
    going to bed now, but will check back here in the morning to see how you’re doing…good luck!
    thanks for helping out a bonehead!
    __________________________
    dual 2 GHz PowerPC Mac G5
    2GB MB DDR SDRAM
    GeForce FX 5200 graphics card
  • Graeme Mcmahon
    August 1, 2007 at 9:06 am
    Sorry,
    It is FCP 5.1 DVCPRO HD 1080i50. HD 1440 x 1080 16:9
    Is this sufficient info?
    When I click on the file in FCP, it comes up with a warning box –
    “codec not found. You may be using a compression type without the corresponding hardware card.”
    When I try to play in quicktime it says, I lack something which takes me to a site which I cannot work out which I need. It does not explain.
    Thank you,
  • Andy Mees
    August 1, 2007 at 10:13 am
    hey G
    I think we’re narrowing it down.
    Sony XDCAM does not shoot DVCPRO HD (a Panasonic format) so the first confusion here is what format th efiles really are, what they were shot on, and how they were captured/trabsfered.
    If they are indeed XDCAM HD files, as I suspect, then the codec is more likely to be Sony’s MPEG HD codec, either 18Mb/s, 25Mb/s or 35Mb/s. I’m guessing (again) the latter.
    Make sure you are using FCP 5.1.2 or above, support for these formats was introduced with 5.1.2. You might also want to install XDCAM Transfer (a free tool available on Sony’s website, for importing/exporting XDCAM media … although I don’t think the codecs come with it, they come from Apple not Sony)
    Of course, I miay have this entirely the wrong way round! It may not be XD footage ata all!
    Andy
  • Graeme Mcmahon
    August 1, 2007 at 12:20 pm
    So what settings should I have if I am cutting footage that has been cut on various formats? Such as a show reel.
    Thank you,
  • Mark Maness
    August 1, 2007 at 2:56 pm
    As for a user of XDCAM and XDCAM HD for more than a year now, I can tell you without a doubt that this is the best and easiest format to use.
    As most of you know, I’m not a fan of P2. Mostly beacuse there is no form of backup for the media. Hard drives fail, so that’s not a permanent form of backup. Blu-Ray is just coming about but that’s what Sony is already using with XDCAM. So…. why not just use XDCAM?
    Ok, enough of that… As for using XDCAM, FCP works flawlessly with it, as long as you are using the newer versions of FCP. But you really do need to have a copy of Sony’s Software Transfer program.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Chris Borjis
    August 1, 2007 at 4:16 pm
    [Wayne Carey] “As for using XDCAM, FCP works flawlessly with it, as long as you are using the newer versions of FCP. But you really do need to have a copy of Sony’s Software Transfer program.”
    so FCP 6 & the sony xdcam software is whats really needed?
    I’m about to get several hours of XDCAM footage.
  • Mark Maness
    August 1, 2007 at 4:22 pm
    It works just fine with FCP 5.1.4, if you have it. But now, Sony’s Transfer software requires at least FCP 5.1.1 to work properly and it works well with FCP 6 (with a minor modification that we discussed a couple of weeks ago).
    What version of FCP do you have?
    Let me say that FCP 6 works absolutely wonderful with XDCAM and XDCAM HD.
    Wayne Carey
    Schazam Productions
