Activity Forums Adobe After Effects viewing fields separately
  • viewing fields separately
    Posted by Dale Paquette on July 7, 2011 at 2:00 pm
    I have some 29.97i footage. I would like to de-interlace the footage and then view each FIELD separately. Is it just a matter of de-interlacing into a 59.XX comp? Thanks
    Kevin Camp replied 15 years, 2 months ago 2 Members · 1 Reply
  • Kevin Camp
    July 7, 2011 at 2:26 pm
    if you simply wanted to view the each field, you can hold alt (win) or option (osx) and double-click the footage in the project window. then step though it in the preview using the arrow keys. (note, ae has to be set to separate fields for that footage first, do that in file>interpret footage>main).
    if you wanted it in a comp, then yes your method is correct (comp frame rate would be 59.94 for 29.97i footage). if the pan is to render out as 59.94 progressive, then you might also want to check the option for ‘preserve edges’ in the interpret footage settings.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
