Activity Forums VEGAS Pro Viewing EX1 clips in Explorer inside Vegas Pro
  • Viewing EX1 clips in Explorer inside Vegas Pro
    Posted by Bruce Quayle on October 21, 2011 at 12:01 am
    G’day folks,
    I have (in the past) been converting my EX1r video clips into mxf format for editing, but I believe that this is now unnecessary as the latest versions of Vegas handle the native EX1r file format just fine. (I have Vegas Pro 9 and 11.)
    The issue I face (and I’m sure it’s due to my ignorance) is that when I look for my EX1 clips in Explorer, I can only access each clip from an individual folder. IE: When I open Explorer, I have: Computer > Drive > Archive folder > sxs folder (with title eg: 20110624123456) > BPAV > CLIP…and then however many clips are on ‘that particular’ sxs card – each in its own folder. So I have to open each folder independently to access each separate clip – a hell of a schlep…if you know what I mean.
    On the other hand, when I transfer the same clips from the same sxs card to mxf files, I get a single folder within which all the clips are included – easy to preview and access within Vegas.
    Could this be a problem I’m causing when I backup the clips using Clip Browser, or am I just missing something within Vegas itself?
    Any help would be greatly appreciated!!
    Cheers,
    Cheers,
    Bruce
    Enrique Orozco replied 14 years, 10 months ago 2 Members · 4 Replies
  • Enrique Orozco
    October 21, 2011 at 2:56 am
    What I do is in Windows explorer make a search for *.mp4 (positioned on the BPAV folder). Now I have all the mp4 data files in one window that I can just drag & drop into the Vegas timeline.
    Hope this helps.
    Enrique Orozco R.
    iDEA DigitalVideoStudio
  • Bruce Quayle
    October 21, 2011 at 3:04 am
    Thanks Enrique,
    I’ll try what you suggest. I still think it should be more “user friendly”.
    Appreciate your input.
    Cheers,
    Bruce
  • Bruce Quayle
    October 28, 2011 at 7:39 am
    Enrique, you’re a bloody genious!
    Thank you so much for making my life that much easier. I search the BPAV file as you suggested and simply drag the files into my Project Media bin. What a pleasure!
    Cheers,
    Bruce
  • Enrique Orozco
    October 31, 2011 at 4:08 am
    glad it helps !! Very easy and forget about mxf conversions.
    regards
    Enrique Orozco R.
