Activity Forums Adobe After Effects Viewing elements outside composition window
  • Viewing elements outside composition window
    Posted by Teeps on October 23, 2007 at 5:47 pm
    How do I see all of my elements outside of the composition window like it is in Flash? I see the bounding boxes obviously, but I want to make fine tuning alignment adjustments without dragging the whole sequence of elements back into the frame.
    Please Help, thanks!
    Richard Garabedain replied 7 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • Mike Clasby
    October 23, 2007 at 6:53 pm
    Hmmm, drag that comp into a new and larger comp, then add a pale colored solid the same size as the original comp, as a background, so you can see the original’s boundaries?
  • Steve Roberts
    October 23, 2007 at 7:12 pm
    Yep … we can only see wireframes on the pasteboard, so yikesmikes way (or similar) is the way.
  • Teeps
    October 23, 2007 at 7:49 pm
    If I create this larger pasteboard with a box in the middle corresponding to the original composition size, is there a way to later crop it back down or would I have to then paste it back into another composition to view it without “extra background”. Or would I not even have to worry about seeing a gray box around my composition if I export it?
    thanks
  • Steve Roberts
    October 23, 2007 at 7:58 pm
    Just drag the big comp into a comp of the smaller desired size and render that.
    Actually, you can drag it in now, and go back to the bigger comp and work there until it’s time to render the smaller one.
  • Teeps
    October 23, 2007 at 8:50 pm
    I just went into comp. settings and made it bigger and then made a rectangle shape with a bright green stroke.
  • Harry Frank
    October 24, 2007 at 1:21 pm
    You can also use the camera tools on any other view. Perhaps you could set “Custom View 1” to the wide view. Even an Orthographic view like “Front” can use the Track Z tool to expand to a wider view.
    A handy trick is to use the Esc key to toggle back and forth between the last two camera views. So you could have comp camera and the wide view easily accessed with one key.
    Harry J Frank
    Freelance Motion Designer
    graymachine.com
  • Quintus Lubbe
    October 26, 2018 at 9:59 am
    I know this is an old post, but you’ve just saved me hours of guess work. Genius.
  • Richard Garabedain
    October 26, 2018 at 2:33 pm
    Ive been using after effects for years and I never knew about the esc key…that “is” useful
