Activity Forums Apple Final Cut Pro Legacy Viewing edit from a distance
  • Viewing edit from a distance
    Posted by Peter Sassi on November 6, 2007 at 2:17 pm
    I remember at the Apple Event at NAB a couple of years ago where an editor could edit and a producer/director could watch and communicate via iSight or some setup like that andybody remember that or have used it?
    Peter Sassi
    Russell Lasson replied 18 years, 10 months ago 3 Members · 2 Replies
  • Rob Tinworth
    November 6, 2007 at 3:44 pm
    I’ve worked remotely a few times using this. I run the analogue output from the edit suite into a DVCAM deck (set to analogue input), and then hook the DVCAM deck via firewire to a laptop. Open ichat on the laptop and just tell it there’s a firewire camera. It treats the deck like a camera, the edit suite treats the deck like a deck. Result is that you can stream the output from the edit suite into ichat. Same thing works with skype.
    Rob Tinworth
    http://www.1021.tv
  • Russell Lasson
    November 6, 2007 at 5:19 pm
    With OS 10.5 you might try using the screen sharing feature in iChat.
    -Russ
