Activity Forums Square Box CatDV Viewing Documents
  • Viewing Documents
    Posted by Justin Mason on January 13, 2015 at 5:18 pm
    Hello all, hope everyone had a good holiday.
    We include in most of our catalogs several documents, paperwork and shoot notes. When viewing these items within CatDV we are only able to see the somewhat small thumbnail provided. Is there a way to view documents on a much larger scale (1:1 maybe)?
    Thanks in advance.
    -Justin
    Popsugar
    Dougal Matthews replied 11 years, 8 months ago 2 Members · 1 Reply
  • Dougal Matthews
    January 14, 2015 at 2:32 pm
    hi
    the largest size a thumbnail can be is 512 x 384 pixels this is set from the thumbnails and proxies section of the preferences see below
    this is a global setting so if you want some thumbnails to be of a different size change this setting then create or recreate thumbnails ( media menu > build thumbnails ) then set it back to your preferred option for other files.
    CatDv can open files in the default file viewer , this can be enabled in the Preferences under Advanced media handling check the Playing non media files Launch in external application option
    see below
    with this selected double clicking on a file will open it in the default application
    eg for a *.psd catdv would launch and open photoshop *.doc Microsoft word etc etc
    I hope this helps Catdv become more useful for you
    thanks dougal
    Improvise Adapt and Overcome
