Activity › Forums › Adobe After Effects › viewing camera in a HUGE 3-D working space?
  • viewing camera in a HUGE 3-D working space?
    Posted by Matt Chapman on September 1, 2015 at 6:29 pm
    I am working on an animation with X,Y, and Z axis. Some of the camera moves that I am working with span MAJOR areas of interest. For example in the current composition (which is at HD res), I am moving the camera from Z=-266 to z=-55000 over about 4 seconds.
    I like the speed of the camera move and the images that I am using are high resolution enough to handle it. They are all 8K images.
    However right now from the top or side views the camera is off of the screen. there isn’t enough real estate to see the camera. I can of course manually enter values, but I like to play with the camera in the “3D” space to get a feel for the move.
    Example of what I am talking about can be seen below:
    FIRST KEY:
    SECOND KEY:
    Is there a way to adjust the scale of the viewing area, or something in order to accommodate bigger scales?
    Chapman
    Kalleheikki Kannisto replied 11 years, 1 month ago 2 Members · 2 Replies
  • Matt Chapman
    September 1, 2015 at 7:04 pm
    I’d still like to know the answer to this, but was able to kinda work around it switching to a One-Node camera and using the “Track Camera” tools.
  • Kalleheikki Kannisto
    September 2, 2015 at 8:12 am
    You can zoom out of the other views in the same way you can zoom out of the perspective camera view, pushing the view close or further out with the “zoom camera” tool.
