Activity › Forums › Adobe Premiere Pro › Viewing all clips in a sequence from the bin
  • Viewing all clips in a sequence from the bin
    Posted by Doug Brown on February 24, 2017 at 8:54 pm
    Is there a way to view all the clips that are within a sequence but from the bin(s) where they live in the project (ie. clip info metadata etc.)? I believe this was “decompose sequence” or some such thing in Avid once upon a time.
    doug brown
    editor-dougitorial LLC
    Doug Brown replied 9 years, 7 months ago 2 Members · 2 Replies
  • Jerry Wise
    February 25, 2017 at 5:27 pm
    well what i do is to make a “bin unused” in the project pane. then go to “edit” “remove unused” then hit undo and all the unused clips will be highlighted. then drag the highlighted clips to “bin unused”. now you have a bin used and a bid unused.
  • Doug Brown
    February 27, 2017 at 10:24 pm
    That worked great. Thanks.
    doug brown
    dougitorial LLC
