Activity Forums Adobe After Effects Viewing a 2D effect layer with camera outside the main comp?
  • Viewing a 2D effect layer with camera outside the main comp?
    Posted by Chris Green on January 30, 2009 at 5:26 am
    I have a scene with a lot of camera movement, and at the climax of the animation I have a 2d particle layer using particular. For awhile I wasn’t seeing the particles showing up, so I remade them in a separate comp and they worked fine…after scrubbing through the timeline I noticed that I could see the particles in just a few frames near the beginning of my animation, but it was not in the center of the comp window like it should have been. I went to custom view and zoomed out and realized this must be happening because my camera is animating far outside of the main comp area. I didn’t realize this was a problem because my 2D background was still showing up, as was the ramp I had applied to it. Is there a simple fix for this? Re-doing this will be an absolute nightmare. I’m also on a deadline so it’s not really an option 🙁 If someone can help it would be greatly appreciated!!
    Steve Rhoden replied 17 years, 7 months ago 2 Members · 3 Replies
  • Steve Rhoden
    January 30, 2009 at 2:30 pm
    Have you tried making the 2d background into a 3d layer?
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Chris Green
    January 30, 2009 at 3:15 pm
    Yeah I did, and I also tried putting the 2D layer into a seperate comp and dragging it in, but then the 2D layer doesn’t maintain the 3D effects. Actually I just figured this out. I was looking through the threads here and found one that was pretty much exactly what I was looking for, and realized that there are separate position coordinates within the particular plugin, so I made a light with no intensity and put it where I wanted the particles to be in the scene, copied the xyz coordinates and placed them into the position in particular and then deleted the light and now it works great 🙂 Thanks for your help!
  • Steve Rhoden
    January 30, 2009 at 3:36 pm
    Glad you got that sorted out…
    Steve Rhoden
    (Cow Leader)
    Portfolio at:
