Activity Forums Apple Final Cut Pro Legacy Viewing 24P footage on LCD NTSC Monitor
  • Viewing 24P footage on LCD NTSC Monitor
    Posted by Michael Barnes on April 14, 2005 at 8:48 pm
    Hi, I am trying to do color correction and I would like to view my footage on my Samsung LCD TV. I bought a Canopus ADVC110 digital/analog converter but that only outputs footage at 29.97. I copied and pasted my footage to a new sequence at 29.97 and I can view the material but what is the point of 24P if you have to work at 29.97. I also tried hooking up my Panasonic AG-DV2500P VTR to the monitor (DV in from G5; SVideo out to monitor) but I cannot view the footage continuously. It only shows clips when the playhead stops. I read the manual and fiddled with the menus to no luck. Does anyone have suggestions on how I can view 24P footage on my NTSC monitor to color correct. Thanks.
    Walter Soyka replied 21 years, 3 months ago 2 Members · 1 Reply
  • Walter Soyka
    April 14, 2005 at 11:54 pm
    Check out the section of the manual on pulldown insertion (p. 1443 in the online help). It’ll keep your footage in 24p, but add a pulldown pattern on playback so you can review it on an NTSC monitor.
    I’d be wary about doing color correction on your LCD, though. A good CRT monitor that you can calibrate will be much more accurate.
    Regards,
    Walter Soyka
