Activity Forums Apple Final Cut Pro Legacy Viewer video quality vs Canvas video quality
  • Viewer video quality vs Canvas video quality
    Posted by Lawrence Richards on May 22, 2012 at 3:10 pm
    Hello CC people,
    What would cause the quality of the video that plays in the Viewer to be better than when the same clip plays on the Canvas/Timeline? For example, there are clips of mine that play fine in the Viewer, but once they’re in the Timeline it’s choppy. And yes, the setting of the sequence matches the footage.
    Thank you!
    Larry
    Thank you!
    Larry R.
    Florida
    Bret Williams replied 14 years, 4 months ago 4 Members · 5 Replies
  • Lawrence Richards
    May 22, 2012 at 5:07 pm
    I did not know that – obviously. Thank you, Dave!
    Larry
    Thank you!
    Larry R.
    Florida
  • Lawrence Richards
    May 22, 2012 at 5:14 pm
    Dave,
    It just occurred to me that that actually wasn’t the question: the question is why or what would cause the quality of the playback differ in the canvas than in the viewer? Like I mentioned initially the video I’m referring to, a clip that has a slow, smooth pan, looks fine in the viewer but in the canvas it stutters a bit.
    Is there a setting or something I’m missing?
    Thank you!
    Larry R.
    Florida
  • Shane Ross
    May 22, 2012 at 5:52 pm
    #50 – Quality difference between Viewer and Canvas
    Shane’s Stock Answer #49 – Why is the quality different between what I see in the Viewer and what I see in the Canvas?
    Well… the viewer is just that– a viewer. It will display anything that fcp will recognize as usable video or graphics. The canvas is a viewer too, but at the pixel dimension specified by the settings of your project and sequence.
    For example, if your graphic or footage is much higher resolution than your 720×480 DV sequence, FCP is interpolating down your file to fit the settings of the sequence. Usually this makes it look not so hot. DV is a 5:1 compression working with a 4:1:1 color depth. Your pristine picture images and graphics are being crushed.
    Same with picture files. HIgh res pics now adopt the sequence settings and will render to those specs, and most likely they are not as high quality.
    Shane
    Little Frog Post
  • Rafael Amador
    May 23, 2012 at 3:44 am
    Right.
    You need to render and set the canvas at 100%, otherwise you are watching just a preview which quality will depends on many variables; Sequence setting, RT settings, system performance…
    rafael
    http://www.nagavideo.com
  • Bret Williams
    May 23, 2012 at 6:02 am
    He did say they match. Assuming he’s correct I’d say check your RT settings for frame rate playback. If it’s set to half, it’d be pretty choppy.
