Activity Forums Apple Final Cut Pro Legacy viewer quality vs. canvas quality HELP!
  • viewer quality vs. canvas quality HELP!
    Posted by Mike Miller on September 24, 2008 at 5:51 pm
    hey all…
    i am creating a video sizzle reel for my agency. here’s the problem. i recorded a coworker as v/o using a panasonic dvx mini dv camera. i digitized the audio from a panasonic mini dv deck going thru aja iohd. i brought the footage and audio of her read in using NTSC DV/DVCPRO easy setup at 720×480. this made my sequence have the same settings. i have also imported several jpeg images to use as assets for the picture portion of this sizzle reel.
    some of the jpegs are smaller than 720×480 (so, i realize if i blow them up to crop in i will experience blurry/lesser quality images). however i have a jepeg that’s 2725×3475 and i actually needed to shrink it to crop into a specific portion of the photo, and that too looks unacceptably blurry in the canvas, but, really crisp in the view window.
    what am i doing wrong? how do i maintain a crisp look for eventual dvd output?
    thanks in advance!
    mike
    Drew Moore replied 17 years, 10 months ago 8 Members · 12 Replies
  • 12 Replies
  • Walter Biscardi
    September 24, 2008 at 6:02 pm
    Get yourself a real external monitor to view your playback.
    https://forums.creativecow.net/faq/applefinalcutpro#59
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • David Roth weiss
    September 24, 2008 at 6:27 pm
    Or, change the RT settings. The canvas is designed to display things in realtime and thus the deafult RT settings lower the display quality to do that. As I wrote in another post earlier today, the user can change the settings to display “high” and instead set the RT to drop the framerate by cahnging that to “dynamic.”
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Andrew Kimery
    September 24, 2008 at 6:36 pm
    Just to add to what’s already been said. What you see in the Viewer is the native file but what you see in the Canvas comes from the timeline. In your specific case the Viewer is showing a hi-res photo while the Canvas is showing a hi-res photo shrunk down to SD size and compressed w/the DV codec. Also, the Canvas doesn’t show images at full quality and needs to be set to 100% in order for both fields to be displayed (if it’s set to less than 100% only one field will be shown).
    As Walter said though, to see what you really have you need to be looking at it on an external monitor.
    -A
  • Mike Miller
    September 24, 2008 at 6:39 pm
    thanks walter. i do have a decent sony PVM-14M2U (20″), but can’t seem to get it to display anything!? if i have firewire going from my mac to the aja i/o hd and i’m going out of the aja (via bnc cables) RGB out to the monitor’s RGB in, i would think that it should display whats on the canvas, again, any thoughts?
    thanks.
    mike
  • Mike Miller
    September 24, 2008 at 6:45 pm
    thanks andrew…that helps, native file vs. compressed sd video. if i changed my codec to something other than DV would that help?
    and my response to walter re the external monitor:
  • Michael Sacci
    September 24, 2008 at 6:46 pm
    [mike miller] “i digitized the audio from a panasonic mini dv deck going thru aja iohd. i brought the footage and audio of her read in using NTSC DV/DVCPRO easy setup at 720×480.”
    As a side note – why are you bring in audio and video this way? If you are capturing to the same DV codec it would be much better to capture via FW from the deck.
  • Walter Biscardi
    September 24, 2008 at 6:49 pm
    [mike miller] ” if i have firewire going from my mac to the aja i/o hd and i’m going out of the aja (via bnc cables) RGB out to the monitor’s RGB in, i would think that it should display whats on the canvas, again, any thoughts? “
    Provided you have the proper Easy Setups selected, you should see your timeline on the external display.
    Read my Blog!
  • Mike Miller
    September 24, 2008 at 7:02 pm
    okay, a little playing around and i now have a nice picture on my sony external monitor. but, now i’ve lost audio! the drop down in fc for audio playback is forcing audio to follow video, all other options are grayed out…? i have been simply using some external speakers that plug directly into the mac’s headphone jack, but now, no sound coming from them?
    thanks for your help, very appreciated!
  • Walter Biscardi
    September 24, 2008 at 7:07 pm
    [mike miller] ” i have been simply using some external speakers that plug directly into the mac’s headphone jack, but now, no sound coming from them?”
    Ok,all of this really should be in the Final Cut Pro Basics forum.
    Your audio is now being fed from your Io HD.
    Read my Blog!
  • Chris Poisson
    September 24, 2008 at 7:11 pm
    Your connections sound correct, is your video playback set to FW?
    Have a wonderful day.
