Activity › Forums › Apple Final Cut Pro Legacy › Viewer & Canvas appear different
Posted by Craig Whitaker on January 22, 2010 at 2:42 pmI have a ProRes file in the viewer and it looks sharp, however, when added to the timeline and then rendered, it looks much softer. I’m sure this is a simple fix, just not sure where to look.
Thanks everyone,
CraigKevin Monahan replied 16 years, 8 months ago 4 Members · 3 Replies -
Tom Wolsky
January 22, 2010 at 3:22 pm“and then rendered”
Why is it being rendered? What are the item properties of the sequence you’re editing into?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
David Bogie
January 22, 2010 at 3:47 pm[craig whit] “I’m sure this is a simple fix, just not sure where to look. “
The Viewer is a QT Player. it will display your movie natively.
The Canvas is a scaled down and compressed representation of the sequence settings, not your clip. Your clip is being processed by the sequence settings and then processed by the Canvas.bogiesan
Kevin Monahan
January 22, 2010 at 6:09 pmIt’s probably the most common confusion to newbs with FCP. You can never judge the quality of your footage on the Canvas. You need to judge it in a separate broadcast monitor. Most people aren’t set up with one and are therefore confused by the Canvas display.
Set up your system properly, with an outboard monitor and this problem goes away.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro
