Activity Forums Apple Final Cut Pro Legacy view playback through HVX200
  • view playback through HVX200
    Posted by Robert Waldrep on September 17, 2009 at 1:38 pm
    I’m trying to use my HVX200 as an intermediate (converter) to view my DVCPro HD 720 footage on a normal tv through the view playback option in FCP using firewire from computer to camera and then composite cables from camera output to tv input……is this possible or do I have to get a capture card and go that route?
    With standard DV NTSC footage using my camera as a link between my computer and an external monitor (tv) is no problem and I thought that the HVX200 would do the HD to SD conversion in camera with 720 footage as well………maybe not.
    Shane Ross replied 17 years ago 3 Members · 6 Replies
  • Shane Ross
    September 17, 2009 at 3:54 pm
    One of the big drawbacks to the HVX-200 was that it couldn’t do playthrough to an external monitor. You can play back the footage to the camera, and see it on the small monitor, and record that…but you can’t then route that thru component or composite to a monitor. HD only…SD you could. I believe that was because of the small 4-pin connector on the camera. The HPX-170 has a full sized firewire connection, and allows for this.
    Shane
  • Robert Waldrep
    September 17, 2009 at 5:21 pm
    So, in order for me to view this HD footage on an external monitor will I have to get a capture card or deck?……or is there a cheaper workaround solution?
    Thanks for the quick response.
  • Shane Ross
    September 17, 2009 at 5:26 pm
    [Robert Waldrep] “will I have to get a capture card or deck?”
    Yes.
    [Robert Waldrep] “or is there a cheaper workaround solution? “
    Matrox MXO2 Mini is $495. Decklink Intensity Pro is $300. AJA IO Express is $495.
    Shane
  • Robert Waldrep
    September 17, 2009 at 6:49 pm
    Thanks again for your help.
  • Mario Rubertis
    September 18, 2009 at 3:56 am
    Shane,
    I think you are mistaken:
    MXO2Mini $495
    Intensity $199
    AJA IO Express $995
    An Artist At Heart.
    Life is made of moments…
  • Shane Ross
    September 18, 2009 at 4:41 am
    AH…I am wrong…I thought the IO Express was cheaper. And I forgot that the Intensity lowered the price.
    Shane
