Activity Forums Adobe After Effects View only layer selected one at a time
  • View only layer selected one at a time
    Posted by Matt Chapman on April 4, 2014 at 8:30 pm
    Hi All-
    I am taking over quite a few compositions from a previous compositor, so I am unfamiliar with a lot of the layers that he has created. Is there a way to quickly view only the layer that you have selected? For instance I would like to be able to hold command and move up and down the layer stack to see only the layer that I have selected at a time, and then switch back to full view.
    clicking solo on and off on 29 tracks per composite is tedious!
    thanks
    matt
    Roland R. kahlenberg replied 12 years, 5 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    April 5, 2014 at 4:45 pm
    Coincidentally, I’ve just sent in a Feature Request to view only active layers in a Timeline. An active layer is defined as being currently visible in the Comp Panel – this of course depends on where the Timeline Indicator is placed.
    Viewing a single active layer lacks context since its relevance only becomes properly defined when viewed with other active layers. In your case, solo-ing is one option. Dave’s given you another. You may also want to look at CTRL+SHIFT+V and/or CTRL+SHIFT+ALT+V to toggle selected layers’ visibility on/off.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
