Activity Forums DaVinci Resolve View node output, not output image
  • View node output, not output image
    Posted by Danny Thompson on August 15, 2013 at 1:41 pm
    I’d like to view the output of nodes on an individual basis. It would be nice to be able to toggle between that and viewing the output image (the default).
    I know that breaking the node chain (having any nodes without input or output connections) can enable this, but it’s not an efficient way to work. I think I’ve inadvertently triggered this mode in the past, but I can’t figure out how to replicate my results.
    Is this possible?
    Sascha Engel replied 13 years, 1 month ago 5 Members · 5 Replies
  • Laco Gaal
    August 15, 2013 at 2:18 pm
    what if you enable only the desired nodes?
  • Danny Thompson
    August 15, 2013 at 2:43 pm
    Not what I’m looking for.
    Seeing the grade up to a node is more useful because it lets me decide what I want to patch into the layer mixer.
  • Brandon Thomas
    August 15, 2013 at 3:34 pm
    Enable highlight on the node you want to view, and it will show you the grade up to that node. Turn off highlight to see the result of the entire tree.
    If you have a qualifier or a window on that node, add a node after it then highlight.
  • Eric Johnson
    August 15, 2013 at 6:10 pm
    In v8, weren’t you able to double click a node to view its out put and single click another node to modify?
    I just checked this is on a lite version v9, and it currently doesn’t appear to work… but maybe that’s the Lite speaking?
    I may also be mis-remembering…
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/39073239
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Sascha Engel
    August 16, 2013 at 10:00 pm
    I only remember this from feature from COLOR.
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
