Activity Forums Adobe After Effects view fields
  • view fields
    Posted by Esra on July 22, 2005 at 7:36 pm
    Hi!
    I am wondering if there is any possibility to see the fields in after effects?
    I mean is there anywhere an option in the timeline that enables me to see not frames but
    the upper and lowerfields?
    Thanks for reading
    Esra
    Filip Vandueren replied 21 years, 2 months ago 3 Members · 2 Replies
  • Roger Burton
    July 23, 2005 at 5:34 am
    try doubling the frame rate in the comp settings window then you can step through the fields…good luck…Roger
  • Filip Vandueren
    July 25, 2005 at 1:19 am
    In the fooatge window, using “Page Down” and “Page Up” will go through your footage 1 field at atime.
    Not so in the comp-window though.
