Activity Forums Adobe After Effects View Double-Sided Image in 3D?
  • View Double-Sided Image in 3D?
    Posted by Marty Arndt on September 9, 2008 at 12:57 pm
    Can After Effects create an animation where you see the front of an image, then move the camera around in 3D to see the back? For example, a wedding invitation with images/text on the front and back of a single page. The page would be upright and stationary while the camera moves to reveal the back side. Hope this makes sense.
    Thank you,
    Marty
    David Coiffier replied 17 years, 11 months ago 2 Members · 1 Reply
  • David Coiffier
    September 9, 2008 at 5:16 pm
    You probably will need 2 layers to do this, but as they can be very close to each other, there’s nothing difficult in it.
    Also, as layers are perfectly flat, there should be a moment in your camera travelling, where you switch from front to back view of the layer. That should happens between 2 frames, so you can also split the layer at this time and replace footage on the last one.
    Only heavy motion blur could make such split hard to do…
