Activity Forums Adobe InDesign View does not hold when swithcing pages
  • View does not hold when swithcing pages
    Posted by Mike Gondek on July 24, 2006 at 7:40 pm
    I have a 24 page docuement for a calendar. Each 2 pages is a month and has “Keep Spread together”. I hit Alt Ctrl 0 on page 1-2 to fit spread, got to 3-4 hit lt Ctrl 0, and when I go back to 1-2 the right edge is cut off again. Why can’t InDesign remeber the positon of my spread, the magnifiacation is remebered. Thsi is really annoyin as I am going between pages often and have to hit ALt Ctrl ) over and over.
    Erica Gamet replied 20 years, 1 month ago 2 Members · 3 Replies
  • Erica Gamet
    July 25, 2006 at 3:13 am
    If you use Alt-Page Up (or Page Down…Option instead of Alt on the Mac) you can scroll through the spreads while maintaining the zoom level…instead of having to navigate to the spread, fit in window and jump back. Of course, you can only scroll through the spreads in order, but you can jump directly to the first or the last spread by adding Shift to the combinations above. Hope that helps speed up the monotony some.
    Erica Gamet
    Digital Dimensions
    https://www.digi-wizard.com/learn
    “…for there is nothing either good or bad, but thinking makes it so.”
  • Mike Gondek
    July 25, 2006 at 2:59 pm
    Thanks, your suggestion is a big improvement.
  • Erica Gamet
    July 25, 2006 at 5:41 pm
    It’s not perfect, I know…but it should cut out several steps when jumping around. Glad to help!
    Erica Gamet
    Digital Dimensions
