Activity › Forums › Apple Final Cut Pro › View clip in timeline’s duration
  • Charlie Austin
    June 8, 2013 at 4:08 pm
    [Matt Orfalea] “In legacy the time between in and outpoints was displayed in the timeline… How can I do that with FCP X?”
    Bottom center of the timeline window. If you’ve got a selection it tells you there… 🙂
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Jeffrey Carter
    June 8, 2013 at 6:54 pm
    You can also select a clip (press C) then ctrl-D to view duration in the timecode window. It’s a little easier to see and you can change the duration by entering a numeric value.
  • Thom Obarski
    June 11, 2013 at 4:54 pm
    for me that had been the case; today for whatever reason ive noticed regardless of where i click it just lists total duration and project settings; any thoughts or should i try to start trashing preferences and the like?
