Activity › Forums › Adobe Encore DVD › video_ts folder
  • video_ts folder
    Posted by Eliza Schu on February 11, 2011 at 7:36 pm
    Hi, I have created two 7gb projects in Encore and hit a roadblock while actually creating the disk. When i try to build to a dvd disk, the program shuts down 3/4 of the way through (after encoding for over an hour). Any idea what I can do to make it work?
    Also, I need to send these to a duplicator who has requested a video_ts folder. What output should I select in Encore to produce this type of file?
    Thanks in advance!!
    Matt Stoddart replied 15 years, 7 months ago 3 Members · 5 Replies
  • Daniel Ludwig
    February 11, 2011 at 7:49 pm
    are you talking about duplication or replication?
    never sent a VIDEO-DVD to replication – for that use DDP-images, especially with DVD-DL-projects.
    cheers
    danny
  • Eliza Schu
    February 11, 2011 at 7:51 pm
    I just need 100, so duplication.
    Do I need to write a DVD image or a DDP image?
    (Thanks so much, sorry for the seemingly stupid questions.)
  • Daniel Ludwig
    February 11, 2011 at 8:53 pm
    if it is only 100 duplications made with a DVD-robot, you need to send an (iso)disk-image.
    DDP-images are required for real repliaction.
    cheers
    danny
  • Eliza Schu
    February 11, 2011 at 8:54 pm
    great, question answered- thanks for your help!
  • Matt Stoddart
    February 12, 2011 at 4:12 pm
    Re: the build taking way to long and crashing 3/4 of the way through.
    I’ve experienced that acouple of times and cured it by
    1) Making sure I have more than enough space for the temp files on system drive (roughly 2x the size of your project).
    2) Clean out the media database (I think in edit > preferences)
    That cured it a couple of times, when it didn’t I just rebuilt the project from scratch.
    Quick questions, Have you ever successfully built a 7Gb project on you system before? Are you 64bit or 32bit and how much RAM are you running?
