Videos with framerates around 37 to 39 – importing into Premiere
I was given some footage that is a combined split screen of a camera capture and a desktop screen capture of a presentation. The resolution is 2560 x 1600 in MOV and the framerate is reported as either 39 or 37 frames per second on the multiple files in Windows file properties. The audio is recorded separately so I have to sync this.
Premeire defaulted to 60 fps on import (which was obviously wrong) which I changed to interpret as 39 or 37 but the timing is still off.
I adjusted the rate to be 63.7% of the original 60 fps that Premiere imported it as and got a close match (which is roughly the equivalent of 38.22 fps. It was still off and drifted. I was hoping to get a perfect match based on accurate interpretation of the captured FPS. I haven’t been able to find any common FPS format (Google search) around 37-39 (drop frame or otherwise). I assume all the files are the same but Windows is just reading them around 37-39 (maybe because of a drop frame format).
I assume I can just do a conversion but why can’t a pro tool like Premiere figure it out on its own while Windows crudely matches it to 37-39? In any case, converting the video is not the path I want to take as I would loose quality and if something can be converted accurately then why can’t it be interpreted by Premiere accurately. Is there a common FPS format around 38fps?
