Activity › Forums › Apple Final Cut Pro Legacy › VideoManSF question
  • VideoManSF question
    Posted by Chris Poisson on June 1, 2005 at 8:51 pm
    Hey,
    Your directions for setting up the BCF 2000 worked great. However, I had to re-install the system and now all my FCP Studio is working, but the controller only works now in Soundtrack and not in FCP. Any idea how to fix? I so far have tried, launching the audio/midi utility and resetting, re-doing the SysEx library utility, turning the unit off and holding the top left button etc., none have helped. Is there a way to reset the controller before I install the firmware?
    Thanks in advance…
    Chris Poisson replied 21 years, 4 months ago 1 Member · 1 Reply
  • Chris Poisson
    June 2, 2005 at 5:48 pm
    Never mind, I got it to work. Just found out about the control surface settings under tools.
